hoon!!!! you better not be doing that kind of shit with our company name plastered down your car :D:P hahahahaha
tosh it would be good for business, people would come in and ask for the "Sideways Special"
mass is a very sensible driver :D
hoon!!!! you better not be doing that kind of shit with our company name plastered down your car :D:O hahahahaha
haha no tosh i wont lol
and as Ed said, it will catch the peoples attention...
but then again we wudnt want the cops phoning powerplay saying it was one of there cars lol tosh u know wat i mean :O
but then again we wudnt want the cops phoning powerplay saying it was one of there cars lol tosh u know wat i mean :D
I know EXACTLY what you mean... hahahah tools
oh i forgot to add, i spotted wils(wilch) 33, nicks (Prank) car at UAS today, while i got a tune done... hope ur car is ok wil, i didnt mean to stop ben from working on it :D
The car's brilliant dude :O
So happy right now. The car feels new. Highest knock on the new tune on the way home was 15 (and I gave it lots), and it still made 271rwkW on this tune at 16psi, 260 @ 14.
It just feels new. I dunno. I was stupid to think of trading her in for a 32 GTR.
I didn't see Nick's car there when I showed up.
Um, Nick isn't Prank. :( Christian is Prank, Nick is Blitz. :(
woops my bad lol got confused... i was told it was nicks car and he said u know prank off the forums... so yeh i guess i was told incorrectly lol
hehe yeh i wont be such a tool with the shtickers lol
Thats because my car isnt there :laugh: Its sitting at CRD atm.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
