Mass,
I still did a quicker time than you did throughout the day and I only drove 5 laps :laugh:
that wud be because of a few things tosh, one u had semi slicks on the car, and two my tyres were fuxored by that time of the day, i had shit all grip :laugh: and yet i still managed a 1:27 :laugh:
Yeah, well I spotted my package and it's still bigger than both of yours! :laugh:
It's on dudes. Next track day you're both going down!! LOL
spotted MAR555 on oxford st. tonight.
didnt realise it was you till i saw your number plate in my side mirror.
and some dude in a huge 4wd stole your plates mass!! it was [MASSIV]
i spotted you on oxford street fri night, but i wasnt driving, was pretty hammered at some clubs, dont even remember coming home.. ahh goodtimes!
Spotted a black 34 in the cross
a black 32 with led tail lights
a white 33 with shopping list
and alot of girls waving at me for some reason.! the city was packed last night, i just went out for an hour or so after my sis bday party couldnt believe how packed it was...
if anyone saw a white 32 with some red nostrils it was me!
i wouldve been the white r33 with the shopping list :)... city was pacckkked last night.. heaps of cops to for the first time in ages... i got done :) and defected
wat u get done for? where u get defected?
saw R34 GTR Possum in nth bondi today! sick!
got done for havin a lil hit with an evo 8, and.. for defects i got some dopey cop pull defects that to my knowledge arent defects!.. he done all this without measuring nothing.. all from his head.. ill tell u whaty io got done for..
1. air filter -
2. blow off valve -
3. boost gauge on top of steering wheel, BUT its under the cluster not over the wheel.. thats not a defect!
4. cold air intake to the air filter
5 this is a funny one "muffler too big"
6 steering wheel - i have a momo with the horn that works perfectly fine.
7 front mount intercooler. its behind my bar.. and is screwed on safely with nothing in its way etc etc..
he was a nice cop though.. didnt get me for anything else... but the highway patrol pumped me...
got court to go to now.. :) ahh well thats my stupidity for ya
i wouldve been the white r33 with the shopping list :P... city was pacckkked last night.. heaps of cops to for the first time in ages... i got done :( and defected
Hey,
Sorry to change the subject but fairly new here and just wondering what do you mean "with a shopping list"
Drew.
Hey,
Drew.
shopping list is stickers with all the brand names of the parts installed (or not installed in some cases) on the car
eg
HKS
APEXI
NISMO
CUSCO
BLITZ
get it?
eg
HKS
APEXI
NISMO
CUSCO
BLITZ
get it?
The stickers down the door, so the thieves know what you got, hence shopping list
Yes I get it now thanks.
Drew.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
