Spotted ranicx and shiftea this morning!
haha, i take off from the lights like usal, ina bit of a hurry cause i needed to get into the lane next to me to pull off onto lance cove, and as im pulling off, i see this white car pull up next to me waving.. where did you come from wink i didnt see you till ya where right next to me? lol
I was in the right lane, 2 cars back and I saw you take off so I gave chase! ;)
spotted mar55sss on george street last night, i was in my girl friends red supra, i tried to get ur attention, but u seemed out of it... hehehe it was around 11:45pm....
I kinda thought it might have been you.. but at the time there was some shit going on involving ambos and the like... you waved right? sorry dude. nice ride BTW.
hahaha yeh i waved :(
i wonder wat happened with the cops etc????
thanks its my girls new ride, only had it for 3 weeks, just put those rims on it and lowered it...
lol u were doing george st happy laps!
nope was heading in to the rocks to pickup a friend, they were at a pub... sif i go down george street :( too many cops :) hahaha hence why i didnt drive!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
