Spotted Ferrari 430 in chatwood but the little dead end lane......some bald guy was driving it and tried to impress the ladies by revving it on his way out. Sadly all he got was a couple of disgusted head shakes, no one was impressed
ok just spotted a dude in a blue r34 GTR with green p plates, on hume highway, the was also a wrx they dragged and i sat back and watched not far behind, wen i decided to give it a hit the gtr turned off :laugh:
but by the looks of it, the wrx kept up with him :D
so i raced the rexy and um hate to say it, i left him for dead :D
also spotted a pulsar sss, with an sr20det in it, man that thing went hard, gave him a run also and only managed to pull away slowly in 4th gear :( it had some grunt!!!
Edited by mass_iv
spotted a white r34 gtr GTR PWR had a lil run with him on silverwater rd
HOLY F*$&%EN SHIT!!! He actually took it out and drove it!!! hahahaha
Spotted Mass just then trying to look hektik in his Skyline on Victoria Rd :P
Spotted Mass just then trying to look hektik in his Skyline on Victoria Rd :(
hahaha sif trying look hektik :( I AM HEKTIK ;)
Spotted me and mass outside the shop in rushcutters tonight....
i was eating some of that fffffffffarken awesome gelato he has to offer! Highly Recommended!!!!!!!!!!!!
hehehe yep that gelato has attracted some of the whores already in the past :ban:
ah the good old gelato runs.....
now on another note, i just got pulled over on my way home from work :ban:
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :ban: this is just not my month!!! stupid 60 zone, shud be 80 :P
now on another note, i just got pulled over on my way home from work :(
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :( this is just not my month!!! stupid 60 zone, shud be 80 :P
ghey
thats MY gelato!!! :D
hahaha sif trying look hektik :O I AM HEKTIK :pirate:
hehehe yep that gelato has attracted some of the whores already in the past :pirate:
now on another note, i just got pulled over on my way home from work :rofl:
i was speeding over that dam old anzac bridge, i copped a $590 fine and am going to lose my licence again for 3 months :( this is just not my month!!! stupid 60 zone, shud be 80 :thumbsup:
oh -MASS- :(
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
