Silver 33GTR with CL ### plates... headed down Mt Ouzley into Wollongong very sedately, stuck behind a slow truck, I gave you some room but you decided to wait...
one very clean ride!
I've also seen a yellow 33 and a black 33 GTR (i think) coming down there too
And a Black 33GTST stopped next to me at the lights in Wollongong near Masters Rd, chick driver, older guy in the passenger seat.
I didnt think to catch the plates.
Edited by B. J.
Spotted a Maroon 33 GTR with huge "Buddy Club" stickers all over it
Also spotted a grey 33 GTST boosting past Chatswood station..series one i think.
Also spotted an S15 with the "Ikeya Sequential" H pattern convertor thing. Man that thing looks chunky....i like it
Spotted a silver and two black R33's (all GTSt's) and a silver R34 GTt sedan heading down the F3, Pennant Hills Rd and the M2 on their way to Friday night drags at EC.
All Central Coast and Newcastle people, apparently...
Spotted Primordial on Monday just leaving just jap!!!
o o o and B-mans Cosmo outside Hitman on Monday night! Looks good! Man those brakes, they are MASSIVE!
Hey! What car were you in? I remember seeing an S15 going the other way when I came out..?
Hey,
I was the R34 GT-T Sedan - I actually live in epping but I work on the coast so hang with them mostly.
Thought it was Goldzilla car but on the two ways the others were thinking of someone else, till that talked to ya.
Drew.
I was in the car behind the s15..... which was the Proton :( lol
I must have missed you by less than 3 mins!!
Hey,
Drew.
Hahaha, hey Drew. I was driving, and my cousin (his username is "blukie") was talking on the UHF CB's. Didn't get to chat for long because the batteries went dead on the CB - I think I've had the same batteries in there since I bought the thing years ago (it must be at least 4 years)...
Who was it that said my car was the "green Camry-looking thing..." over the CB's? :(
Even worse is that someone didn't know what a Stagea was - there are a few up Newcastle way, and they are on the forums too! :ninja:
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
