Spotted a silver R34 sedan on Beecroft Road this morning
Hey Wink, That was me! Did ya see me crazy waving out the window as usual??
Somedays i start at 10am at Erina so i always along beecroft rd that time.
Drew.
Drew.
Nah didn't see you wave but in my defence we only see each other for a split second!
Saw green stagea wagon STR86T on Church St North Parra at around 2:40pm. I was in a silver Jaguar X
Didn't see you, but I was kinda in my own world around then...
Spotted a white r34 gtt near the corner of flushcombe and main st btown
nice chromes..looks hot!
Was it parked, Albert? If it was near your work, that must be the one I was talking to you about at the Christmas Cruise...
Also spotted STR86T (Goldzilla) yesterday arvo around 6.30pm on Fitzwilliam Rd - not sure if you saw me wave, I only saw you at the last second when you flashed your lights...
Spotted a very dirty MSP-25T with some random bloke driving it :)
Engine looks and sounds very nice Mona ;)
Yeah, I only spotted you at the last second too, otherwise I would have waved as well...
On another note, spotted some drunk motherf**kers outside Great Northern Hotel.
Yeah, I saw them too - the bunch of clowns! ;)
yeah it was parked infront of jake n chesters, didnt see the guy, i was cleaning the benches at the time lol
spotted some tard in a 4door r33 trying to be fully sick on the main road in richmond around 3am thismorning...
car sounded like shit as well.. typical skyline driver you hear about in the news
While out and about in the last week ive spotted two mean sounding GTR's both with screamer pipes, one was down near orange grove krispy cremes last wednesday i think, it was gun metal with number plates UREADY, second one on woodville road near Fairfield street last friday number plates GUN RB, both sounded like they had some good gear under their hoods
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
