Spotted a silver R34 sedan on Beecroft Road this morning
Hey Wink, That was me! Did ya see me crazy waving out the window as usual??
Somedays i start at 10am at Erina so i always along beecroft rd that time.
Drew.
Drew.
Nah didn't see you wave but in my defence we only see each other for a split second!
Saw green stagea wagon STR86T on Church St North Parra at around 2:40pm. I was in a silver Jaguar X
Didn't see you, but I was kinda in my own world around then...
Spotted a white r34 gtt near the corner of flushcombe and main st btown
nice chromes..looks hot!
Was it parked, Albert? If it was near your work, that must be the one I was talking to you about at the Christmas Cruise...
Also spotted STR86T (Goldzilla) yesterday arvo around 6.30pm on Fitzwilliam Rd - not sure if you saw me wave, I only saw you at the last second when you flashed your lights...
Spotted a very dirty MSP-25T with some random bloke driving it :)
Engine looks and sounds very nice Mona ;)
Yeah, I only spotted you at the last second too, otherwise I would have waved as well...
On another note, spotted some drunk motherf**kers outside Great Northern Hotel.
Yeah, I saw them too - the bunch of clowns! ;)
yeah it was parked infront of jake n chesters, didnt see the guy, i was cleaning the benches at the time lol
spotted some tard in a 4door r33 trying to be fully sick on the main road in richmond around 3am thismorning...
car sounded like shit as well.. typical skyline driver you hear about in the news
While out and about in the last week ive spotted two mean sounding GTR's both with screamer pipes, one was down near orange grove krispy cremes last wednesday i think, it was gun metal with number plates UREADY, second one on woodville road near Fairfield street last friday number plates GUN RB, both sounded like they had some good gear under their hoods
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
