Spotted a neat purple cefiro with drift teks and nismo kit going up Warringah rd through Beacon Hill..
And a silver 180 with black roof and R33 GTR rims looked like a drifter.
Edited by phillb
Oh, I spotted a black 32GTR in hornsby - it was in a parents with prams parking spot...and it had p plates..........hope you had a pran.....
Dammit.. I have a GTR looking black skyline 32.. and i was in hornsby! some one friggin spot me
>> no i didn't park in no pram spot though... so prob wasnt me
Edited by chinkeboi
Yesterday arvo at Manly spotted a white R34 GTT coupe with black bonnet and yellow tailight covers!
I've seen this car a few times around Manly, dunno whats the go with those yellow taillight covers :laugh:
Spotted like 5 skylines going down beecroft rd this morning around 8:30, one included Wink he was beeing followed by a silver R33, the others were before him a white R33, maroon R32, black/grey R32.
spotted ETHOLL this morning!! cruising along! :rofl::P
yay! finaly been spoted.
i didnt know your car was back on the road already, sounds good though
white r33 would have been me heading to work. silver r33 would have beem moanie
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
