Spotted a white R33 with black or carbon bonnet today in my travels - can't remember where. Don't think it was Wil, though, I didn't notice any signwriting on it...
yay! finaly been spoted.
i didnt know your car was back on the road already, sounds good though
white r33 would have been me heading to work. silver r33 would have beem moanie
I thought it might have been Wink as i always see him at that time but must have seen him earlier...
spotted some coasties tonight, and some hornsby-ites
spotted EVIL _WEEVIL driving up to visit the coasties tonight even tho his car was misbehaving and making him so annoyed and unhappy :P awwwww ;)
AND.....
he brought his girlie up to meet us too, Georgie :) thanx Chris!
Can someone scream, "COPY CAT!!! FREAKIN COPY CAT!!!" out the window next time they see this car please?
Yeah I've seen that one around too.. Looks very similar to Wil's
Spotted DHC parked at the Entrance today.. Very clean.
Reminds me I need to wash my car.
Yes, a wash indeed...
...not many pics of your dirty beast last night mate. :(
and what's DHC?? Daihatsu Handpolishers Club???
we both go along that road in the morning to work, i somtimes see him when im running late lol
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
