spotted quite a few at dinner and terrigal and everywhere,
mikie and myself also spotted bout 5 180's and a sprinter at brooklyn on old pac - 90% on plates - gave em a friendly toot but got death stares back - wtf?
kids now days have no respect....
Spotted a pearl white R34 four door on Warringah rd on Saturday arvo and on my way back from the Gong I saw a White series 2, gunmetal series 1 and a black V35 with Bronze Volk CE28N rims :thumbsup:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
