are you from the area?
yerp. i know norm! and used to have my cars down at where par's old shop used to be on beaconsfield st.
cant say i've seen you around tho.. wouldnt be hard to miss either.
i got a wingless 32 gtr in dark blue
Spotted a pearl white R34 four door on Warringah rd on Saturday arvo and on my way back from the Gong I saw a White series 2, gunmetal series 1 and a black V35 with Bronze Volk CE28N rims :laugh:
Hmm, I wonder where Warringah road is...
Gunmetal s1 may have been me...
Spotted Black R33 series 2 GTS25t going up Kiora rd in miranda this morning plates NIC-***.
Yeah RUGAME use to drive a black R32GTST got the SIlver GTR32 the Greek PIzza's are good HUGE and FILLING.. damn i'm hungry now.
oh ok, if i see you ill beep!
my mates live all over the area so im always around. i get my hair cut at rogers across the rd from chicken wizard too.
i saw like 25-30 skylines over the weekend and i only knew one of them... that was the Nate Tune Skyline which is now naked and awaiting new decals...
i saw 3 on the way home from work, which for a 7 minute drive is pretty good, 2 on the way to macquarie centre, 1 at macquarie, 3 or so at thornleigh maccas, there were also like 4 86's and a bunch of other tuner cars that were pretty good... went to just jap on satuday so that boosted the amount by a few...
basically, i gotta network...
yeah... i always see RUGAME parked on the other side of the rd... very nice car
Spotted WTF-33R at the wall last night.
WTF? can you please be a little more specific? what wall?
yesterday spotted a Black R33 S1 Sedan heading the opposite way on Rookwood Rd on my way to the Gong. Spotted a white R33 on New Illawarra Rd near Bangor Bypass.
Spotted a silver R33 with nice blonde driving it out of the street next to holden in Gosford this arvo, then spotted a silver coupe with zoro graphics down the side of it following me before he turned off towards woy woy @ bottom of kariong hill.
Then spotted Anna (MsNismo) on the F3 she was going down the big dipper as I was comin up it, finally spotted a yellow R34 Coupe on the F3 @ mooney mooney bridge.
ummmm drew... what do you mean big dipper??? I get on/off at berowra... perhaps mooney? And I didn't see you ... ;)
lol at zorro graphics!
btw spotted zoomer at Berowra yesterday arvo... looks like he had just picked up smiley
If thats your car in your avatar, then yes I'd say it was you fat33!! I was in the soarer so I doubt I'll ever be spotted on here LOL..
ummmm drew... what do you mean big dipper??? I get on/off at berowra... perhaps mooney? And I didn't see you ... >_<
Yeah Mooney Mooney is the big dipper isn't it? The last hill before the gosford turn off, you were in the fast lane naturally and had the window down with your trademark sunnys on.
It would have been around 5:45 or something like that about 7mins before i sent sms as it didn't send and it kept retrying until it worked.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
