I'm currently in Canberra at my aunty's house in Kaleen, and right next door I spotted a gunmetal R33 sedan parked with NSW plates, JVxxx (I didn't look at the numbers properly).
Hi to all;
Just bought a nice r33 gtst and was out for a cruise and spotted three skylines. One in Landsvalve (r34), one in Bass Hill (r33), and one in Burwood (r33). All in one night and all had the UNIQUE PRO SERIES stickers on the their cars. Does anyone knows what is UNIQUE PRO SERIES???? Have seen it on alot of performance vehicles.
it's a workshop somewhere around bankstown (can't remember where they are).. i went on a cruise with them a while back.. nice bunch of blokes!!!
I spotted Liz's new toy.
YAY!!! Not long now! :P
YAY!!! Not long now! :wacko:
Thanks Liz, I spoke to a guy today at cumberland macers after I spotted his 200sx wearing the UNIQUE PRO SERIES (nice guy). I asked him where did he get the cool stickers and it is in fact from a workshop in Villawood called UNIQUE AUTOMOTIVE. He too said that they are really nice guys. Will go and see them tomorrow. Will let you all know how it goes. It's hard to find good workshop when you are a chick.
spotted a wingless red R34 driving into richmond yesterday
That guy from richmond. Banned from this forum and any cruises, due to doing burnouts, and speeding everywhere(he got NOS).
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
