I'm currently in Canberra at my aunty's house in Kaleen, and right next door I spotted a gunmetal R33 sedan parked with NSW plates, JVxxx (I didn't look at the numbers properly).
Hi to all;
Just bought a nice r33 gtst and was out for a cruise and spotted three skylines. One in Landsvalve (r34), one in Bass Hill (r33), and one in Burwood (r33). All in one night and all had the UNIQUE PRO SERIES stickers on the their cars. Does anyone knows what is UNIQUE PRO SERIES???? Have seen it on alot of performance vehicles.
it's a workshop somewhere around bankstown (can't remember where they are).. i went on a cruise with them a while back.. nice bunch of blokes!!!
I spotted Liz's new toy.
YAY!!! Not long now! :P
YAY!!! Not long now! :wacko:
Thanks Liz, I spoke to a guy today at cumberland macers after I spotted his 200sx wearing the UNIQUE PRO SERIES (nice guy). I asked him where did he get the cool stickers and it is in fact from a workshop in Villawood called UNIQUE AUTOMOTIVE. He too said that they are really nice guys. Will go and see them tomorrow. Will let you all know how it goes. It's hard to find good workshop when you are a chick.
spotted a wingless red R34 driving into richmond yesterday
That guy from richmond. Banned from this forum and any cruises, due to doing burnouts, and speeding everywhere(he got NOS).
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
