spotted DJ Brave in the tree lines, bunkers and dam at Royal Asquith today!
And Tinks in the club house with us after :(
Top day!
spotted the evilist weevil playing golf when he SHOULD have been with his mrs..... :)
:blink: charm your way out of trouble did you????? lol!
haha yer brooo...didnt know where to wave or not coz half of the skyline owners around st.clair arent SAU associated. they give me the wtf look haha.
and thx haha everyone loves my muffler sound
Me and my lady are in St Clair... dont mean to give a WTF look, just checkin out the rides... Mine is black R33 GTST with FMIC and stock wheels... the ladies is white R33 GTST lowered, with bomex front and off white AVS wheels... I am sure i saw you at the mamre road bridge...
yesterday working all day fun fun. spotted yellow r33 on forest road right outsiide my work peakhurst iga next to the pub at 10. then amy33 at 10.40 then later on a black r33 with no spoiler didnt get plates
Edited by dyken
This morning on the way to work at the corner of the road that leads to The Sydney Adventist Hospital spotted a Silver R33 GTR at the lights me tooted and waved as i drove past.
On the way home from work spotted a Silver R32 GTR with numbers plates R32*** or 32R***... the plates were the silver writing on black -this was going thru gosford up kariong hill then when we hit the f3 he was ahead.. i got off @ Hawkesbury Bridge to avoid the traffic hope you didn't get caught up.
Then along pennant hills rd as i turned off onto beecroft spotted a White R33 with green p plate sitting in traffic i tooted and waved and turned off.
Saw V8HNTR going west bound in M5 east tunnel few hours ago...
nice looking silver R33..awesome number plates...
however...i must say...
thumbs down for attemping to impress 2 asain ladies by dropping it a gear or two in the next lane, giving a quick squirt but not really covering any ground...plus driver was by himself...tsk tsk tsk...must have a massive ego... you better not lose to a V8 and give us a bad name.
Edited by mle808
Went to Young out in the sticks over the weekend, and spotted an R31 (plates were "R31"), and two black R33 GTSt's (one had a GTR badge on it).
Out in that area it's Commodore, Commodore, Magna, Commodore, Commodore, Statesman, Commodore ute, Commodore, Commodore, Falcon, 4WD, Commodore, 4WD, Falcon, Commodore, Camry, Commodore, Statesman, Falcon, 4WD, Commodore ute, Falcon ute, and then your usual assortment of small cars...
saw a white series 1 R33 with yellow plates AJ 67 GW or some other random shit... i flashed them, and i got a flash back AND a wave out of the passenger side!!! thats the first reply ive ever gotten :)
also saw ASN 34B (silver 34) in Hornsby when i was dropping some stuff off... looks nice, needs some work though >_<
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
