White 33? I didn't see that one. I was working so of course my car was there lol
Was it parked further up near magic kebab burnsie?
nah mate right up near the the round about. it was like 3 cars in front of urs. and im pretty sure it had a sau sticker on it on the back window. and i think it had red plates
spotted ethooolll this morning on beecroft road.. also had someone in a silver 34, 4 door (?????) wave to me on beecroft rd.. he was going in the opp direction... i'm sure i saw an sau sticker!
Might be Drew aka lanky71
He's in Epping
yeh was going to say drew.. i spotted him in epping too a while ago
well where is lanky71 to confirm :laugh:
Yep is was me! Thought you were Wink as he is the one I usually see along there.... but then 5mins l8ter he flashed me further up beecroft rd.
Haven't had a chance to get on SAU since wednesday night. Usually on everyday!
Spotted R34 GTR (CYIFLY) at towers waved
Spotted R32 GTR (ANS***) at baulko aswell.. Waved and got one back
Yep was me in 32. Spotted you too. Just spent over 5 hours getting car laptop road tuned driving up and down Windsor rd all arvo.
lol! sif! his car is white, mines silver! :P and nice ride!!! :P
spotted a silver R32 on clevland st at about 9:30pm,
very tidy yellow R34 with carbon fibre bonnet over the harbour bridge, followed him for a while then pulled up alongside and gave a wave, window tinting too dark to see if i got a wave back or was snobbed...but either way, nice ride.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
