Sam, it was parked in Franklin Street. Although I didn't get too good a look at it, I'm sure it had chromies (nothing too over the top, thank god) and a rear wing on it - I'm pretty sure I would have recognised your car even if it was from just a quick glance.
ah cool.. yeh def wasnt me then lol
spotted some dark colour 34 4door i think parked around the corner from me in the dark near the park.(Get a Room) LoL
and a silver r34 BBZ *** come hooning past me on Doonside Road
not even 5minutes ago.
spotted a few imports in the carpark on my first day at work today :)
also spotted caine at MAC center at lunch today... didnt get the chance to scream out or stop u.. i was going up the elevator wen u got to the bottom lol...
mainly s15's no lines tho :D
Edited by mass_iv
mainly s15's no lines tho :)
*clears throat*
Spotted Marsss on Parra rd near Petersham heading towards the city.
I was in the Hiace going the opposite direction, hahaa beeped at your for aaages..
yeah got the SMS.. as you can understand.. if a Hiace is beeping at me.. i ignore it with gusto... but i'll know next time :rofl:
y is it everytime i spot somone they're never a member of SAU?!? I've been meaning to actually send in my membership form/money but i've been out of work (its been really hard because my skyline needs some work done and i can't afford it) I think i've figured out y i haven't been spotted...because it looks like a piece of junk with bad paint...i just wish i had a decent looking 'line!
I think i spotted security today at lunchtime outside subway/oportos off canterbury/milperra rd
If not, it was a yellow 33, bodykit - plates started with auf i think
I was the guy driving the gunmetal 33 >_<
you'll find that alot of the cars here are a work in progress mate. mine being one of them. took me a while to get the paint sorted.
I was the guy driving the gunmetal 33 :)
yeah mate that was me, i saw you but didnt get a wave or anything so i didnt think too much of it. and when you see a bright yellow r33 you KNOW its me, not think :domokun: . my mate [username: vexed on here] was there too with the blue r33.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
