thats the one, i was under my car heard turbo jumped up and saw that drive past
I didn't see you there dude , I was there to inspect a car for a friend in Coachwood place, he was in a liberty .
Spotted Abo bob on victoria rd gladesville near the ryde aquatic centre around 7ish this evening
And you probably would have seen Chubbs in the grandpa spec 31 behind me. Must have been a bit later than that though. That's also about where the lancer tried to take me out. Do you drive a lancer in your spare time... :thumbsup:
lol! you snooze, you lose :P
you end up buying the helmet? :)
hahaha. No didn't end up getting a helmet after realising there wasn't going to be a discount. :( I'm going to head out to Parra and see what they have.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
