spotted burnsie last night at wsid....few lines, mainly 32's and 33's....i also spotted the hot chick driving yb50ft....car was pretty hot too....ran a 14.2 with shocking 2.7 60ft....
yeah but she did have a high mph good for low 13's but she left early with problems
u sure it was silver.....i was on there but i got a white s2 with AYB...
Im not colour blind lol, Yeh was definately silver with nismo lower lip and maybe 17'' rims i was walking to get some food for morning tea maybe 9.30-10.00am?
Sorry bud....wasnt questioning your ability to distinguish colours....just thought maybe it was at a distance...
Hey its cool didnt think you were questioning my ability to judge colours he he :thumbsup: ... ill prob see you some time i work on vic rd
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
