I think i spotted prime cordial (Jon) coming out of thornleigh maccas this morning.....gave it a squeeze....it was me crossing the road when u took off....
Oh that was you? Heya! :P
LOL, that guy/chick lives down the road from me, always parked outside, nice lookin ride wit red rims and no spoiler rite ?
Was very nice although i did notice a bit of damage to the stealth wing on the back. Don't know how you could manage that?
Hey Adrian,
I live in Hurstville too, welcome to the forum! >_<
I drive a Series 1.5 R33, plates SL33KY, no more p plates either!! :glare:
Cool! I was hoping for a few people around my immediate area. Looked like most of the people were out west or something!
I'll keep an eye out for you. I got a white s2 r33. Complete stocker atm but should have some engine mods and rims by the end of the month
Spotted Slim this arvo on epping rd
also blue 34 gtr "POSSM" near towers, a black 34 gtr on sunnyholt, infront of it was a white 31
ah so that was you!
Also spotted LUKEY 9 I think the plates were.. Blue R33 in Baulko
Saw a Black R33 today parked at North Sydney TAFE. Has Nismo stickers here and there, as well as a Series 2 looking wing
If you took a walk around to the back of the car park (near the spray painter area) you would have seen my Skyline :(
Im from very close to there aswel :(
Look out for a black JZA80 supra with dark tints and super low side skirts
POSSM is a nice looking car. They had the 98 GTR V-Spec before.
Too bad it's mummy's car eh? That's the "chic" behind the wheel.
yeah im pretty sure was some mid aged woman drives it, sounded so awesome though
Nope, ive got a black supra and a white GTR - sorry, no black skylines :)
Bahh ... I need to pay more attention to what I'm typing late at night :(
I meant supra where i wrote skyline haha I think I should be heading to bed
Haha yeah thats cool
Nah not near Lugarno, but if you see a black supra driver waving dont be suprised :)
Spotted marsss yesterday on cnr of hume hwy and stacey st near bankstown/greenacre
damn... my cover is blown...
(note to self.... be fooly sick elsewhere)
around that time i spotted a 4 door white 34 with a very nice looking chicks in it uleh
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
