Spotted Zilch when I was leaving work this arvo..... sounds good!
Spotted Lizzeh @ St Ives.... waved but after I spotted you in my rearview mirror!
And a white stagea on Pac Hwy @ Chatswood........
Spotted the autostyle R32 GTR in the back streets of beverly hills tonight, followed by a white R33 gtst series one auto
Then on the way home - another white R33 gtst, but not auto - it sounded really good, i tried to say hello but you turned off the highway to early
myself and a mate in our 31 GTS1's went for a photoshoot down on Pt Kembla (just south of wollongong) some douche in a white 33 thought it was fun to come along side each of us and drop a fully schit dose, shoot off down the road and weave between traffic ;)
Saw a beautiful red 32 GT-R on the way thru Appin on Sunday arvo... it was very sexual, I have a feeling it was widebody.
Saw wraith_skyline this arvo, passing the caltex on Anzac pde just past the uni.
I can spot ya a mile away with those nismo stripes mate, nice. ;)
Haha Sean we so didn't see you!
spotted blue r32 gtr with red p plates and massive chromies in forster maccas carpark 9am
Pretty sure that isn't legal
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
