who the f*k is Jason?
JET-32R was owned and built by a guy named Lucas
Yes it was :P
JETR32 on here (Jason) did not sell his car i believe... or did he?
Also spotted Anna this morn on the way to work... NIGHT RIDER! :D (during the day time)
Also spotted Anna this morn on the way to work... NIGHT RIDER! :P (during the day time)
:D ... for the last time... its not Kit... its not night rider... its the Black Bish No 2!!!
btw was half asleep and didn't see you this morning... assuming it was in the same spot as usual???
spotted wink parked yesterday at manly and also a silver r33 series 2 parked at manly aswell number plate ***33r
both nice looking cars
Yay. Thanks!
Finding street parking in Manly beach on a sunny Sunday afternoon is bloody hard. So lucky I got that spot - and the Skyline wouldn't have fit in there either! :D
Spotted in Chatswood yesterday "DR SKY" white R34 coupe.
LOL guy obviously abused the shit out of it because that car has been going for the past 2-3 years without even the slightest of issues
i used to drive it all the time and it was great
I'm always seeing GTR-97V around Dural in the arvo's. It's a nice, clean white one. Not sure of the model tho..
And the other day spotted a nice pearl purple 'Line out at Bunnings Dural, it looked mean
Obviously :laugh:
I mean everybody knows that it takes an entire 3 days to kill the big end bearings on an RB26.
Your mate got the better deal, mine now has to try to find the money for a rebuild.
I havent actually had a chance to trash it yet wanted new tyres and brakes before I did that
just driving home casually last night and it starts dropping oil pressure then it started the big end knock :laugh:
LMAO what a joke
funny how people who i know saw you thrashing the arse out of it
but it conveniently dropped oil pressure while "casually" driving home
really? I was just casually driving it home at the time, but regardless whats done is done, I bought the car now its my problem
and my idea of thrashing is more than just a squirt every now and then which is all ive had a chance to do...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
