Spotted one of the hottest R34 GTT's ive ever seen today on pennant hills rd about 2.30ish, it was bright orange with an awesome kit & wheels plates R34-SKY If your on the forums man u have done a nice job!
Spotted v_s_p_e_c and SAM916 at my house the other night (Sunday or Monday??) .... lucky those tyres were still there in the morning boys!
Also spotted an R33 - SKZ01D on my way to Ryde yesterday... ummmm epping rd I think I was turning on??
spotted a black skyline at erina yesterday arvo around 4, think it was br3tt off these forums, your girlfriend was driving, i was pulling out of the driveway for supercheap and you went into the next driveway, cant remember the shop tho. i had to stop at the lights and saw you get out of your car and stare at mine for a while lol
i was going to wave but i didn't want you to look at me funny just incase you weren't off the forums lol, nice car btw
thats Caine :rolleyes: aka Shif_tea aka Monas Boytoy..
spotted an awesome looking silver R34 GTR at Watson's Bay at 4pm.
grats to the owner :)
I wonder if it was the same R34 GTR I saw in broadway & 45min later parked on oxford street near bondi junction? Green P plates, 19''rims & exhaust... Very nice for a P PLATER
I spotted SKZ-O1D on oxford street also..
thats Caine :thumbsup: aka Shif_tea aka Monas Boytoy..
and hes such a good one too :P
its NOT what you're thinking :rolleyes:
Nah wasn't me... my car was running like a bag of shit tuesday and sat in the garage and my girl can't drive manual :rolleyes:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
