Spotted this evening around 6pm on York St in the city I think it is? A white R33 with carbon fibre boot and stealth spoiler and blueish looking graphics or writing on the sides, I was on the Anzac Bridge so you probably didn't see me.
Spotted a silver V35??? with SAU stickers at the M4 homebush off ramp early morning around friday last week. My girlfriend also saw this car yesterday on her way home from the city.
spotted a couple of R32's, S15, couple of S13's, buzzboxes and some random V8's all on the F6 at around 12pm last nite....looked like they had come back from doing a nasho run or something and i just ended up in the middle of they're cruise, was all very spontaneous and random.
Keep spotting a Silver R34 I believe its a GT model as it has the GT rims.
I think a asian girl drives it, may I add extremely attractive when I saw her one morning.
Dont know who you are, but often see your pride and joy. Hope your on here!
Oh I drive the R34 Black with Impul rims. Oh in chatswood :(
See you round.
There was a meet at P6 last night Sam, was probably that.
spotted the sexiest purple 32 in north rocks today.. man that color is HOT!!!! sorry i didn't let you in.. was so damn busy drooling!
also spotted a purple 33 at the bp on seven hills rd.. was a purple evening!!! would have been complete if i'd seen your car, -MASS- :)
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
