Spotted JJH 086 I think it was? white seriesII 33 near Chatswood/Willougby - was in teh 31
seen him in chatswood aswell, he was at the pizza cruise, only recently got the car, nice bloke, not sure who he is on the forums tho...
lol i was waiting for a post in here to see who it was that was yelling out to me
i love the cross be it in the clubs or in the car
looked like you weren't drinking enough dude, you were still standing when i saw ya :domokun:
yeah its a good place. yeah mate i was sober as i drove in so it was all good. man gota love mates that work for engery australia free parking in sub stations so noone can touch me car.
thats gotta be one of the most ingenous parking tricks i've ever heard of.... :domokun:
*runs off to find someone that works for energy australia*
where do you the sticker from?
ive seen a few on the rd, i like it :domokun:
Unless you can read chinese there's this site www.taobao.com that sells basically everything c
onversion rate is 1 Aus Dollar = 6 Chinese Ren Ming Bi (People's Credit)
on the other hand if you can't then there's always eBay
eBay transformers decal
mine looks similar to those except they are 3M reflective which are the best quality stickers in the world.
I got a 1 metre long POLICE sticker for the doors as well but not so sure if it's against the law or not
so I haven't put them on yet, does anyone know?
Edited by POLICE
Few shops around sell em, seen at the motoquipe and autobarn in Mt druitt just to name a few
not my cup of tea, but I'd prolly go decepticon If I had to pick
Also spotted my old R33 again! Gave the driver a wave but don't think she's on the forums
Spotted myself being held up in the daily grind by a white R33, looked like 17s, getting put on the back of a towie in Sans Souci.
Hopefully all is well :) Definately wouldnt of been a crash, must of been car troubles..
Went out for lunch, saw a black 32 in hornsby near the bowling alley, it then followed me to waitara maccas... plates were GTS-25T or something along those lines... i was the idiot in the merc waving my arm out the window :rofl:
Also saw a blue 34 GTR pretty much as I passed pymble pub, plates BNR34... Very nice lookin car! :O again, I was the idiot in the merc waving and honking :D
i've seen that GTR around Lindfield a few times aswell....he never waves :)
spotted MADGTR at about 11:30 near the ranch
heard things about this guy...hot car tho!! spotted a white r33 on samantha riley today about 7:30ish
Edited by NG0387
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
