Spotted JJH 086 I think it was? white seriesII 33 near Chatswood/Willougby - was in teh 31
seen him in chatswood aswell, he was at the pizza cruise, only recently got the car, nice bloke, not sure who he is on the forums tho...
lol i was waiting for a post in here to see who it was that was yelling out to me
i love the cross be it in the clubs or in the car
looked like you weren't drinking enough dude, you were still standing when i saw ya :domokun:
yeah its a good place. yeah mate i was sober as i drove in so it was all good. man gota love mates that work for engery australia free parking in sub stations so noone can touch me car.
thats gotta be one of the most ingenous parking tricks i've ever heard of.... :domokun:
*runs off to find someone that works for energy australia*
where do you the sticker from?
ive seen a few on the rd, i like it :domokun:
Unless you can read chinese there's this site www.taobao.com that sells basically everything c
onversion rate is 1 Aus Dollar = 6 Chinese Ren Ming Bi (People's Credit)
on the other hand if you can't then there's always eBay
eBay transformers decal
mine looks similar to those except they are 3M reflective which are the best quality stickers in the world.
I got a 1 metre long POLICE sticker for the doors as well but not so sure if it's against the law or not
so I haven't put them on yet, does anyone know?
Edited by POLICE
Few shops around sell em, seen at the motoquipe and autobarn in Mt druitt just to name a few
not my cup of tea, but I'd prolly go decepticon If I had to pick
Also spotted my old R33 again! Gave the driver a wave but don't think she's on the forums
Spotted myself being held up in the daily grind by a white R33, looked like 17s, getting put on the back of a towie in Sans Souci.
Hopefully all is well :) Definately wouldnt of been a crash, must of been car troubles..
Went out for lunch, saw a black 32 in hornsby near the bowling alley, it then followed me to waitara maccas... plates were GTS-25T or something along those lines... i was the idiot in the merc waving my arm out the window :rofl:
Also saw a blue 34 GTR pretty much as I passed pymble pub, plates BNR34... Very nice lookin car! :O again, I was the idiot in the merc waving and honking :D
i've seen that GTR around Lindfield a few times aswell....he never waves :)
spotted MADGTR at about 11:30 near the ranch
heard things about this guy...hot car tho!! spotted a white r33 on samantha riley today about 7:30ish
Edited by NG0387
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
