Hey mate it didnt look like this did it?
thats on my desk here at work :(
was in HPI
and it is definatly bodyform.. as thats what the sticker is on the window.
the seats have the GTR logo on em too
spotted a white 32 GTR with Blitz and something else written up the side in large font... also had QLD plates...
Then spotted almost immediately after that a black 33GTR go past me...
I was also infront of a police officer the entire way to work, and didn't even get a second look! :D
I was in a mazda MX5 :D
I did see him give a thumbs up to another officer though, so they do the same thing that we do :banana:
This morning I spotted a Gunmetal R32 GTR with Gold 5 spoke wheels and blue headlights heading North on Military Rd Neutral Bay, I waved but you probably couldn't see with all the rain :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
