Spotted a grey R32 four-door parked at a servo kinda half-way between where the Krispy Kreme/Harry's/Megacentre and the intersection of Cumberland and Hume Highways meet.
Spotted EXH-45T near Warrawee
And LI-22-EH in the same place.. Honked when I went past Liz but I bet you had no idea who I was.
you were in a pulsar, yes?
spotted LI22EH parked on the street... anyone want some rims? :P
oh sup
spotted duncan this morning on beecroft road or something.. i didn't wave incase he banned me.
I don't know much about Stagea's but there is always one parked out the back of Mitre 10 in Wentworthville, white with gold rims, anyone on here?
Spotted a silver stagea today at towers roof carpark "BEO..."
Post these in the Stagea spotted section, we might get some answers! There's a link in my sig, too...
I might have to go and check this one in Wenty out, though, it's not far from home. Did you get the plates, SL33KY?
Yep. White n14 with a pushed in rear end hahah.
Today spotted a white R33 GTR near Chatswood.
Also spotted a blue R32 GTST or GTR parked at BP near the airport, big chrome impuls.. looked really clean from a distance.
Hey anth... hahaha thanks for the work man.. it was worth it.. spewing though about the 4th run i was looking forward for a better time...
PS: guys i recommend Anthony at Dahtone racing for good value for money and reliable performance work :thumbsup:
shit box civics that blow up and spill oil all over the track should be crushed
tell me about it.. i dont get why they are allowed to run man, they ruin it for everyone..
PS: also spotted anths sex machine 2GU UP man ur car sounds sex.. love that screamer
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
