Spotted this morning on canal rd St Peters of Princess hwy black R34 *AN-36-DR* with body kit and that high wing. It looks OK because it has the whole kit so the wing blends in shame about the rims, nice one. :thumbsup:
Dave
spotted a white r33 putting around infront of my work thismorning as i drove in.
BAK *** plates, poor bloke was spluttering and back firing but slowly took off as i jumped out the car.
Hope you nursed it somewhere safe dude.
Best of luck
Spotted a black 34 GTR Broadmedow this afternoon... LOUDEST THING I HAVE EVER HEARD AT IDLE!
sure it wasnt a GTT with fat wide rear guards?? I know one that was reeeeeeeeeeeally loud at idle..
hahah well spotted chriscross I thought the car was pretty well hidden where it is. i always just let the navigator battery run down when I park the car.
isn't it fun getting in there? I love a blat up the tunnels.
hahaha so its you! :yes: Ive seen you there a couple of times now. and yes I totally agree on the tunnels :)
The first time I went in there I gave the dude a funny look when he told me where to go ;)
Just thought I'd mention the nav, just in case it might be connected to the battery n draining it :)
nah its all cool thanks mate, ignition power only. are you parking an r33 up there? hadn't seen one.
and it took me 60 f**king minutes to get from the city to kel's work pyrmont tonight. lucky i like the girl
Yep. but I usually get there after you do, and leave before you :D...but somedays Im there a bit earlier. hehe
60 mins to Pyrmont?! holy crap....it took me about 25 mins to get onto the harbour bridge...and then another 15 or so, just to cross it....grr.....
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
