spotted greg yesty
i waved after you passed, took me ages to realise who it was! I'm so slow
I spotted him too! On Friday :D Pacific Highway a bit before Chatswood...
Then spotted Qantas (Hempy)(SN33ZE) on the same road 2 minutes later IN Chatswood :D
yeah I spotted them too, I heard they were crusing doing happy laps n shit!
wtf... you were at Auto Salon? :rofl:
Saw a silver Stag on Old Northern Rd this morning. Gave a quick wave but he'd passed already.
Spotted an R33 in Parramatta tonght, plates were BL-35-ED.
Also spotted a few of you down at AutoSalon today. Looking tidy, crew.
:P And you didn't come say hi?!
spotted a 34 GT-t at rouse hill shops yesterday (i can't remember the colour - i think it was silver)
and this morning i spotted a black 34 Gt-t turning into Caltex on Windsor rd at about 7am, and a burgundy 33 at the lights in norwest
spotted a purple with yellow lip tone around the hole car at cabramatta station and number plate MSBTCH...but there was a guy drivin, false advertisin man...lol
Edited by 5hu7o
This morning saw a black R32 gtst going into the Harbour tunnel from the northside. plates ended in 5ONA i think.
What time? Could've been me but my plates are different. Mine are [RR3322].
Spotted a Black R32 Gtst in from of Tracks last night.
Parked out the front or driving past? I went past at about 7:30. :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
