For the Newcastle people out there (btw why can't we have our own thread? This one seems very Sydney based. :banana: )
Spotted a nice Pearl White R33 4 door out near Wallsend at about 3:30 I guess. I was in a grey R32 4 door at the round-a-bout and my brother was behind me in the white R31 :thumbsup:
-Jimmy
Edited by -Jimmy-
ok wtf... was it red?!?! and the chick blonde?!
nar, close enough was maroon lol
but she was blonde
must just be sad people out there who can't think of anything else to take photos of besides imports and themselves in their bathroom mirror :(
Yeh same, was parked waiting to pick up a friend at their work and across the road in a camry was a girl taking a picture of my car from her camera phone :P
:dry: the same thing happened to me
I was driving along parra 2 weeks ago to ANZ stadium 4 the soccer match
and when I looked in my rear view mirror, I saw this girl/woman in her car taking photo(s) of my car with her camera phone
quite weird ah
saw a nice white r33 series 2 on monday afternoon going down pennant hills road at pennant hills at around 2.30 saw he got cut off by some wanker driver in a hatch back....
You guys might want to look up your number plates on the rate the plate website.. might be snappin photos for that
Hey never knew that existed, I've got some rating to do lol
Can hardly see why in my case as I was parked and where the other person was could only see a side view
So who saw the Gun metal 35 GT-R on the M4 today...
"blueline" from the R31 forums snapped this up:
FYI, Mates workshop was compliencing that car. Forgot the name of the workshop but its in the Fivedock (sydney) area. Apparently the owner paid around $250k for it. The owner also instructed the workshop not to take any photos.
