Spied a pair of white 33's at work (Morriset Square) on Sunday - One non-turbo S1 driven by some kid who looked like he was about 12. :rofl:
2nd one was an S2, low, big f*ck off FMIC and no frontbar.
On the M2 citybound this morning I saw that same black R33 that I saw the other evening pulled over. It drove past me just after the tunnel past the Beecroft Rd on ramp. BLA-33K are the plates.
Then saw a Volvo on fire on the Eastern Distributor! Crazy. The whole front was up in flames.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
