Spotted two really nice Skylines today, both on Seven Hills Road.
First was a wine red or red over silver two-tone R31 Silhouette with BBS-style mesh wheels near Cropley Drive.
Second was a black R32 GTSt, also with mesh wheels (different to the '31, though) on the border of Bella Vista.
Both cars were VERY clean!
Saw a grey 4dr R32 like mine with black front bar (I think) going into Westfield carpark. Anyone know him? Shits me that SAU doesn't have a Newcastle Spotted thread :D
Also saw a pearl white 4dr R33 near KFC Kotara.
-Jimmy.
Edited by -Jimmy-
Saw a grey 4dr R32 like mine with black front bar (I think) going into Westfield carpark. Anyone know him? Shits me that SAU doesn't have a Newcastle Spotted thread ;)
-Jimmy.
Start up a Newcastle spotted thread Jimmy. Im always spotting skylines around Newy
spotted a white r34 without a wing driving westbound on victoria road dundas, gave me a wave but i am alittle slow at these things..... i was the silver r33 gtst waiting at the lights
saw a mad looking 350gt on woodcroft rd with the drivers side door totally crumpled. i was retarded with my camera and couldnt get a pic. pity dude - looks like you had left your door open and someone drove into it? or you reversed into something with your door open. unlucky anyways - your car is hot.
spotted xmetal drinking my jim beam at erina tonight
also spotted qantas at the round about at wyoming(the one that goes accross the train line) i was in my gf's car..i beeped the horn!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
