Spotted 2 lines on my way home from work today.
Silver R33 parked on Herbert St in St Leonards with plates: BFG-05Q (green P plater)
Black R33 heading towards Chatswood Chase on Victoria Avenue with plates: XBT-273 (I think).
Both looked pretty nice :>
spotted a hot lookin 34 yesterday at norwest, plates were NZMO34, also spotted a black 32 near baulkham hills tafe, a silver 32 turning off victoria ave, and a bayside blue 34 GTR JA-77-** in kellyville..think it was the top secret imports car
spotted at castle mall today, some lebbos parked next to you with red or green p's and were looking through your windows and i parked a few spots down and hung out for a minute untill they left.... i'm assuming this is r34liners car?????
oh oh that white R34 was the 1 i saw on pennat hills rd the other day :):P:D lol freaking hell ur cars look similar lol...
spotted yesty a black 34 with no wing, lowered, with noiiiice mags going down silverwater Rd at like 10:00, i was like 5 cars behind ya lol... and a white stagea going south along pennat hills rd at 2:00 saw ya 2 late 2 wave :banana: devo lol
oh oh that white R34 was the 1 i saw on pennat hills rd the other day :(:(:D lol freaking hell ur cars look similar lol...
spotted yesty a black 34 with no wing, lowered, with noiiiice mags going down silverwater Rd at like 10:00, i was like 5 cars behind ya lol... and a white stagea going south along pennat hills rd at 2:00 saw ya 2 late 2 wave :( devo lol
i know ay!! - i cant belive ther are 2 white r34 n/a green p platers in the same area!! thats just not fair lol - this is my area biatch :( - anyway next time you do see a white NA r34 with green p plates - make sure it has a - skylinesaustralia - sticker on the back windscreen and blue number plates with p plate zipped to the plate and NISMO sticker on the windsreen ;) i doubt ther is many skylines that look like that :(
Spotted Black R34 GTT on Winsor Road last night - wayy to dark to see any waveing tho
Spotted a M35 Stagea parked out the front of Repco in North Parramatta on Sunday. Looked very clean :(
Also spotted Abo Bob hanging around under my car :( Thanks again mate
spotted you in my driveway :(
Spotted about 1ish on Pennant Hills Rd, a silver R32 GTR and a black R33 a few cars behind it, waved at both but got nothing back :wub: I was in the blue R33.
Aww :( awkward movement hahaah!
Spotted "SLM.75J" today again on Sunnyholt rd
Spotted 2 black 33 GTST's parked a few spots apart in campbell st artarmon today. Plates BBU-*** and BDQ-***. Both had nismo stickers on the sides.
Also spotted a silver 33 GTR plates GTR-*** in lane cove industrial area. Gave a wave, then my tyre blew out seconds after lol.
lol wah????? so random, everything under controll i guess????
also spotted for a couple of days now a burnt orange r33 at macquarie (bank) i mean park, parked next to douglas hanly moir car park...
and shitty that mobil on corner carlingford road and beecroft road is out of 98 ron fuel again :D forced to fill up at penno BP that is way over priced
spotted you in my driveway :laugh:
:down:
Spotted a white R33 on pac highway in chatswood this morning with blue "HKS-33*" plates
Also saw that Duncan left his navigator on again ;) That can't be good for the batteries :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
