spotted goldzilla bout 20mins ago at 12:20 waiting to turn right west bound onto M2 from penno hills road.... late coast cruise i presume?????
Spotted Tom tonight at the intersection of the M2 entry and Pennant Hills Rd while I was on my way home from the Coastie Cruise.
(Well, I know I spotted a silver R33, now I know who it was... :()
Also, this afternoon at around 6pm(?) I spotted Jason Round in the HPI project Mitsubishi Galant, heading along Old Windsor Road from Northmead towards the Hills.
Spotted a few revheads giving it a boot past Pennant Hills Inn, 2 R32(silver and black)s, 1 R33(black), 1 R34(silver, SAU sticker), 1 Evo(darkblue) :(
Also spotted a maroon R33 cruising past same location and a silver R32 GTR stuck behind a bunch of bogandores.
spotted sheng again at another broad minded person fest music festival, he was with another SAUer but i dont remember names anymore.....
lol no wai!
saw you too!
rest were Haysey aka bundyloose, and jon
bit late but spotted a green stag around westmead area around 5.30pm fri arvo with sau sticker on it.
Prob Nick (Godzilla)
Spotted a white R33 S2 "BO.55.RB" this arvo on sunnyholt rd driving like a absolutely tool :devil:
and also a silver R33 S2 mins later, plate were "DR.33.GT"
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
