spotted a silver series 2 R33 gtst on oaks road (always bloody see lines there) this arvo at 12.30pm, he gave me a wave but i was too slow to react coz i was playing with my stereo lol.... car looks nice and clea aswell *waves @ driver online*...
also white r33 with strange body kit followed me on windsor road at bout 1.40-2 ish north bound, he turned onto m2....
spotted a silver r33 with chromes and tinted windows driving up highs road on tuesday arvo at bout 3.30pm, i flashed you couple times and you looked stunned....
just spotted a tops GTT or GTR Black on Epping road Lane cove. Looked wild I think it was a GTT with GTR nose shiny as shit and I think from memory has GTCs or similar. Would have been 19's by the size of them.
Top looking ride mate was really nice.
speaking of sliver R35's
this was turning into the business park at Lidcombe where the NSW Nissan H.Q is. Didn't get the rego, but it was more than likely the same one I saw last friday just down the road.
(pls excuse the wiper smear on my windscreen)
Spotted a bright red 32 GTR in Richmond, very neat, think it was on here for sale?
Then a burgandy red r33 GTS-T in north richmond.
Then a burgandy red r32 GTS-T driving towards north richmond.
Then another r33 GTS-T drivind towards north richmond.
phew!!!
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
