Seen a grey 32 at Bungarrabie roundabout thismorning....Looked gey with black lip??? he gave me a wave...sweet!
Then a white 33 turning off Vardy's rd onto Davis rd Marayong both on the way to work this morning.He waved too.
I should drive the line more often.
Spotted a grey 33 on Harris RD Five Dock. Guy was getting out and was either stoned, had just woken up or was very very confused because all I got was a glare in response from my nod.
Also saw a beautiful looking Silver R32 GTR as I turned right off Concord Rd onto Homebush Bay Drive just after 12pm. He was heading south and sitting at the lights. SOOOO CLEAN! Gave a thumbs up and got a nod in return.
yesterday spotted a black/dark grey r32 gtr at giffnock avenue maquarrie park about 11am with plates RB VIP or RB RIP, i flashed and he waved, mean looking car that one....
last night bout 8ish going down davies road through bankstown bout 7.30pm there was a red p plater in 4 door r34 non turbo, blue or silver colour that i couldnt catch up to in my lightly tuned gtsT get done in the bum after what looked like he drove into something on the road like a pot plant or a trucks retread tyre and it was wedged under his car, or someting at the front of his car fell off and got stuck.... anyway if your on here slow down abit for your own safty and less damage to your car.
afterwards alfords point road white series 2 r33 gtst was following me for a bit
cheers all
That was me bro. Nice R33 you have dude.. looked good.
Plates are RIP V8 :D
Plates are RIP V8 :P
hahaha thanks,,,,, cut me sum slack i just got back from europe and i was driving to work (last place i want to be) lol, im still in holliday mode, number plate is even better sounding now, i love it
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
