Seen a grey 32 at Bungarrabie roundabout thismorning....Looked gey with black lip??? he gave me a wave...sweet!
Then a white 33 turning off Vardy's rd onto Davis rd Marayong both on the way to work this morning.He waved too.
I should drive the line more often.
Spotted a grey 33 on Harris RD Five Dock. Guy was getting out and was either stoned, had just woken up or was very very confused because all I got was a glare in response from my nod.
Also saw a beautiful looking Silver R32 GTR as I turned right off Concord Rd onto Homebush Bay Drive just after 12pm. He was heading south and sitting at the lights. SOOOO CLEAN! Gave a thumbs up and got a nod in return.
yesterday spotted a black/dark grey r32 gtr at giffnock avenue maquarrie park about 11am with plates RB VIP or RB RIP, i flashed and he waved, mean looking car that one....
last night bout 8ish going down davies road through bankstown bout 7.30pm there was a red p plater in 4 door r34 non turbo, blue or silver colour that i couldnt catch up to in my lightly tuned gtsT get done in the bum after what looked like he drove into something on the road like a pot plant or a trucks retread tyre and it was wedged under his car, or someting at the front of his car fell off and got stuck.... anyway if your on here slow down abit for your own safty and less damage to your car.
afterwards alfords point road white series 2 r33 gtst was following me for a bit
cheers all
That was me bro. Nice R33 you have dude.. looked good.
Plates are RIP V8 :D
Plates are RIP V8 :P
hahaha thanks,,,,, cut me sum slack i just got back from europe and i was driving to work (last place i want to be) lol, im still in holliday mode, number plate is even better sounding now, i love it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
