Spotted a Green P plate Silver R34 gt (BCF ***) on Taren Point road city bound on Saturday night driving like he was on FNF. I know the P plater next to you had a "Drift Gansta" sticker on the back of his car but ffs swirving at him and cutting through lanes like you did is an absolute joke. Its wankers like you who give all import drivers a bad name. Grow up an learn how to drive.
spotted 3 r35 gtrs @ EC
also spotted the winfield r32 + gtsr + Neil, jetwreck @ EC also
Oh man, I only saw the one R35 yesterday, the red one being used as a safety car or whatever.
I also spotted the Winfield R32 GT-R, the R31 GTS-R, and the Bluebird, as well as Neil, Jetwreck, Andy65b, Big "JET" Jason, and a few others here and there...
Spotted a yellow R34 with big shopping trolley wing :P in eastwood on sunday. Also had transformers stickers on it and a big ding on the right hand side.
And this morning a black 32 on pac highway in pymble plates were AM**XT.
Also, W8INDQ in lindfield n had a quick chat. :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
