Loads of Skyline at Oran Park.
any of you guys see MAD 34! :) That thing was CRAZY! Sounded soo good!
+2, so many skylines in the carpark, let alone in the venue at OP!!
i got to see MAD34 drive in and park....i nearly creamed myself when i heard it pull in....
saw a r32 gtr today parked at some mechanics or somthing at riverwood with the plates fear
also spotted a 32 gtr with the plates gg 32 tr at clempton park outside some mechanics
Edited by Grk_R33
Spotted a 180SX Type-X with a SAU sticker getting fuel at St Ives. I would have chatted but... I'm lame :P
Ah, that would have been me! I thought your number plate looked familiar, but I wasn't sure. I was in a hurry to get back to work anyway.
Spotted an Orange.. err I mean silver v series skyline.. covered in orange dust driving down epping road about 1.5 hours ago
Yes. Today in Sydney orange was the new white...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
