:ninja: caught the rear end of you :laugh:
Yeh i almost missed you too been a while since i seen your car think it was the crispy cream to the gong cruise over a year ago, still havn't seen another blue one around other than ours.
Yeah i know its been ages! i saw non-turbo one at stanhope shops the other day lol.
Spotter a nice lowered blue Fairlady Z on the The Comenarra Parkway yesterday at about 5PM
If it's the 350Z I know, it isn't lowered, it just has Amuse front bar that sits pretty close to the road :ermm:
Has Fairlady Z and Nismo badges on the rear?
Spotted KIW 18U Blue R34 GTR on Windsor Road this afternoon
Then this evening spotted BJC 10S on James Ruse and then on Windsor Road
Silver R34 GTR V-Spec Standard I think
I was in the Evo 9 Champ
If it's the 350Z I know, it isn't lowered, it just has Amuse front bar that sits pretty close to the road >_<
yeh sounds like we are talking about the same one! except this one definitely looked lowered :cool: ....but then again I was behind him!
forgot to post this yesturday...
Spotted a Gunmetal Grey R32 GTR number plates - R32GTR on Pennant hills rd around 1:30ish in the arvo.
Gave a wave but not sure if you sore me cause of all the traffic.
SN33ZZ is Hempy's old plates, he got a new car and I don't think he kept him. Don't know the new owner...
Spotted a MNP3 (? - was 2 or 3) R34 GTR at chatswood today
Spotted Mitch Mr Moo, gave a wave, dunno if he saw
Spotted Demir's R35 outside his shop after having an argument about wether or not he has one with a co-worker of mine :)
Spotted Demir's R35 outside his shop after having an argument about wether or not he has one with a co-worker of mine :happy:
no i did not see you. where did you wave.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
