Thats the one! lol. Neat car.
Cheers man :-)
What sucks is ive been driving this car for 4 years and have been spotted ONCE, yet my gf has been driving it for the past week or so while her cars off the road and 3 diff people from SAU have told me theyve spotted her.
Also spotted a white r34 with big black wing boosting up banks dr in st clair about 20 mins ago.
Cheers man :-)
Hate to make matters worse but i think i spotted ur gf in parra on friday night around 5.55pm. I was jogging on the sidewalk on the way to the nissan dealership. SAu sticker on the quater window right? And i think it also had a GTR bar and grill? mmmm...bar and grill....
yep that was her lol...
saw BUL-37T at the car park next to Blacktown tafe
also, theres is always a red R32 gtst at the automotive side of tafe(Blacktown) car park
You go to Blacktown TAFE? me too! LOL
is that the one with USW next to it?
If so thats where we hold texi with all the epic skids.
JOIN it in the events section. it's uber fun
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
