At lest yours isn't run on 5 cylinders half the time :( . It cuts in and out as I'm driving.
By 'stuff', do you mean like parts..?
yeh parts :)
the main ones are:
HKS EVC or Blitz I-Color Boost Controller
Splitfire coilpacks
Platinum spark plugs
then tune
more stuff to come later :P
awesome looking red R35 outside rpa, and not exactly a skyline but owen strutting his stuff through rpa :(:)
haha yay!
yeah i get to check that gtr out all the time dude, one of the doctors there owns it.
that big beige building down the bottom of that road you went down? that's where i work :P
I just spotted a silver R33 GTSt on Dunmore Street in Pendle Hill (rego BMX66F) and a wine red R32 GTR with R33 GTR wheels parked opposite the pub (alongside the railway station) on Wentworth Avenue in Pendle Hill.
yeh parts :D
the main ones are:
Splitfire coilpacks
then tune
more stuff to come later :)
Awesome mate, I got Platinum plugs atm. I got told my car is running down on a cylinder mostly because of the coils packs, so thinking about getting Splitfire ones as well. :P
White R33 GTS25t, spotted on riverlett hill (great western near Lithgow) about 5:30, out the side window of my Wife's bog stock '07 Corolla 1.8, while I went round the outside as he was using racing lines and looked to be having a go, sorry I overtook you in a standard shopping trolley, twice, in corners while your mate watched on, But we will pretend it was the straights that matter hey?
Hmmm. Wasn't me, though I would have been coming back down the Mid-Hartley Rd (the back way) from Lithgow just a half hour earlier in a car with a very similar description. Small world.
BTW. I'm sure you're fully tuff and all, mate. But isn't that part of the road a big building site, and aren't the speed limits 60kph? Perhaps he was just being sane?
YAY 08 WRX! How's it goin man?
good mate, sorry for the late reply. Been smashed at my new job. PM me your email so I can send you my new work one. The wrx goes well - just needs to make a bit more noise and ride on stiffer springs...and possibly some wider wheels...in white. It begins lol.
spotted Pezhead, MRSAMO, Godspeed, Terry, lankanboii at Top Secret Imports on Saturday..
Yeah, was good see'n ya. And was cool to have three GTR's line up with the two Evos and Silvia on the opposite side of the road. Awesome sight so much power just waiting on tap :down:
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
