At lest yours isn't run on 5 cylinders half the time :( . It cuts in and out as I'm driving.
By 'stuff', do you mean like parts..?
yeh parts :)
the main ones are:
HKS EVC or Blitz I-Color Boost Controller
Splitfire coilpacks
Platinum spark plugs
then tune
more stuff to come later :P
awesome looking red R35 outside rpa, and not exactly a skyline but owen strutting his stuff through rpa :(:)
haha yay!
yeah i get to check that gtr out all the time dude, one of the doctors there owns it.
that big beige building down the bottom of that road you went down? that's where i work :P
I just spotted a silver R33 GTSt on Dunmore Street in Pendle Hill (rego BMX66F) and a wine red R32 GTR with R33 GTR wheels parked opposite the pub (alongside the railway station) on Wentworth Avenue in Pendle Hill.
yeh parts :D
the main ones are:
Splitfire coilpacks
then tune
more stuff to come later :)
Awesome mate, I got Platinum plugs atm. I got told my car is running down on a cylinder mostly because of the coils packs, so thinking about getting Splitfire ones as well. :P
White R33 GTS25t, spotted on riverlett hill (great western near Lithgow) about 5:30, out the side window of my Wife's bog stock '07 Corolla 1.8, while I went round the outside as he was using racing lines and looked to be having a go, sorry I overtook you in a standard shopping trolley, twice, in corners while your mate watched on, But we will pretend it was the straights that matter hey?
Hmmm. Wasn't me, though I would have been coming back down the Mid-Hartley Rd (the back way) from Lithgow just a half hour earlier in a car with a very similar description. Small world.
BTW. I'm sure you're fully tuff and all, mate. But isn't that part of the road a big building site, and aren't the speed limits 60kph? Perhaps he was just being sane?
YAY 08 WRX! How's it goin man?
good mate, sorry for the late reply. Been smashed at my new job. PM me your email so I can send you my new work one. The wrx goes well - just needs to make a bit more noise and ride on stiffer springs...and possibly some wider wheels...in white. It begins lol.
spotted Pezhead, MRSAMO, Godspeed, Terry, lankanboii at Top Secret Imports on Saturday..
Yeah, was good see'n ya. And was cool to have three GTR's line up with the two Evos and Silvia on the opposite side of the road. Awesome sight so much power just waiting on tap :down:
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
