i have actually spotted you and handful of times now. no point posting up to re-spot the same person over and over.
lol thats cool.
Ive only been spotted once on this forum and I've been around vic, qld , & nsw now in my car.
Least i know now I've been acknowledged :P
cheers.
SPOTTED: Teren's Panda Stagea last saturday arvo heading on to old windsor rd.
I was passenger in the greenish blue VY commordore
Edited by Sloane
Spotted a white R34 GT-R, GTR-34U parked at windsor KFC this evening about 6pm.
Ha ha that was me! Was at the church bar, tight ass tuesdays!
How long were you at the lights for?
also spotted a silver R33 GT-R (GTR-33C) on saturday on Old Windsor Rd (think it was saturday!)
Sounded insane.
Also saw a white R32 GT-R in Rouse Hill, think the plates were MY GTR or something
Saw a white R33 S1 GTST stopped by police in Penrith tonight, on Henry St, just up from the Sinclair Ford dealership.
They had the bonnet up, and were walking around it, defecting everything in sight.
Sad.
Spotted a white R34 GTT (I think) while I was coming in to Lithgow from down the Mid-Hartley Rd (great twists!), and he was going the other way.
I flashed the headlights; he gave thumbs-up.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
