now spotted twice, blue bnr34 "34VSPEC". he's waived at me both times, im wondering if he'll let me drive his car now :headspin:
in the city the other night, "HPI-34T" - not ben ellis, but another guy who works at the same publishing company as him - was quite a buzz cruising down george st. with him too :D
hmmm....did I see kinks in a 31 today??? :confused: thought you had a pulsar Geoff??
Haha yes you did see me in a 31.. :D
still have the pulsar, but it's the backup / sister's car... :)
I was napping a bit waiting for a gap in the traffic, didn't realise it was you until you were already swinging past.
Cheers B-Man.. :)
I've seen that one too (on Parra rd). I'd pass up a blowie just to see it go by a few times in a row.
heh...
i saw a midnite purple BNR34 tonite at OzTag - "UGLY" apparently Ugly Phil from 2dayfm's old car...AND a silver EVO6 GSR(? didnt quite see the front or was close enough to see the rear stickers :D)
I keep seeing a Skyline Gts25t in West Ryde, nice silver stocky looking one plates Nizoom then ran into her at the bank but didnt say anything :D
and me and my Mate Craved have bone seen a Black R32 in castle Hill/Baulkham Hills on Old Northorn Rd and Windsor Rd , who have waved at us but dont know who it is, I can understand Craved getting a wave, but I wasnt even in a skyline so I have no idea whats happening there ..
I saw a blond chick in a nice black 33 on Alison rd yesterday, waved and got a dirty in return. I should have said, "I was trying to pick your car up, not you," but the lights changed and I was too slow.
Story of my life!
Story of my life!
gold! can I borrow that response!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
