Blue 34 GTR - number plates were '34GTR' or something or rather on Silverwater Rd. yesterday. soo orgasmic pinch.gif
Huge f**K off spoiler the car was about to take off into sky! pretty sure i saw an SAU sticker.
Thats Terry's (Terry_GT-R34) previous GTR, unsure of the new owners name but that thing is pretty orgasmic lol
yeah have they taken his nutrimetics sticker or whatever that ad was for off the rear bar yet?
As soon as i read that post and the giant F off rear bar i thought of his old car, one of the best looking GTR's in the country i do declare..
Spotted Seans white R34 GTR on the M4 this arvo, was driving my filthy M35.
Yep spotted you, looked pretty clean to me :) I waved when I was behind you haha!
Also spotted gunmetal 32GTR, 34R wheels with sau stickers on side windows, followed me down M4 for a bit, nice car!
And a black 34GT-T
Chik drivin r34 gtr past chicken wizard with the plates akh around 9ish this morning and the same silver 33 that goes on lehn road overtook me being a hero and its non turbo and also saw a silver 32 gtst on river road about 15 mins ago
And a black 34GT-T
Nice cruising with you, very nice car :)
Spotted BNR32 with BNR34 front end on Wednesday on M5
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
