on friday night, spotted a white R33 driven by a hot looking gal (well from the neck up coz I couldn't see below that, I'll let my imagination handle those parts), driving on George St in the Rocks 2 blocks down from jacksons on George.
Also had a small squirt in my mum's 93 Corolla (shoulda borrowed my old man's ceffy dammit!) against what looked like a canary yellow R32 that had its inner tail lights snipped. First time I've seen those aussie spec taillights on an import model and they looked wierd. This was on Saturday night on Parra Rd heading into the city, he turned left somewhere near Rick Demilian's showroom i think.
Had so much fun drivin my mum's car lol... handbrake halfway up in an FF car off the lights while sitting next to a WRX that was riced off its nuts on cnr Elizabeth st and Oxford St. Took off with tyres screechin the whole way till the next lights. WRX pulls up to me winds his window down n goes "wtf mate?" to which I reply... "I drive a skyline usually, my bad :D"
About 11am this morning spotted a hot blonde in what looked like an 89 blue pulsar! (Wasn’t a skyline, but that baby could have given one a run) nice kit, big bling rims, damn it had some work done to it! Flying down great western, towards Parra racing a VT! I didn’t have time (or risk the points to catch up to it)! But I would love to give it a run... damn she was giving it, I’m surprised the turbo didn’t blow through the motor, I don’t know what the VT was thinking! He didn’t have a chance!
Standard plates, XY something?
She would have looked better in my car :P (Passenger of course) :D :D
Guest barbie iz a bitch
She would have looked better in my car :) (Passenger of course) :):D
Heyyyy since when am I spotted :D
I dont race.. I was simply trying to loose that freak that had been following me from penrith.. :Oops:
Passenger?? hmm i dont think so.. just because we are female we arnt accessories.. so dont push us to the passenger seat!! :D
Yeah the car looks good.. pitty about half of the front bar I left on the first ramp driving into work on saturday avo.. :P
I prefer my charade.. less attension LOL
Did it sound non turbo and have mesh, chrome wheels? If so, that car used to have the plates "4BNEVL" - seen it around my area a bit. It's not to shabby for a n/a.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
