Last Night Wed (23rd) on Victoria Rd from West Ryde to Roselle. Spotted 3 R34s (2 black and 1 blue i think) all next to each other, they were obviously friends, all were done up quick nicely.
Came up to them in my 34 and we pretty much cruised together from ryde to roselle, giving a few small bursts now and then, nothing silly.
Was quite a pleasant trip to an otherwise pretty dull everyday commute.
So hey guys i was in the black spoilerless, cwest/kit 34 .
At about 11am I saw an orange line parked in Roselands Shopping Centre - YSL??? - looked like it could do with some work - Green P Plates.
Then on the way back home on Parramatta Rd, Auburn - saw a blue line, blue number plates "SY" - pretty awful turbo if you don't mind me saying. I was cruising in my mate's Astra and she was still able to beat it!
saw a yellow R34 drive past the ranch on friday night, didnt get the plates I was inside as it caught my eye out on the street, and saw I silver GTR in west ryde, parked in a no parking spot as they went in to get some drinks from the pub, then got followed by an undercover cop ...
i am a new member, i own r33 GTS for 1 year, i wanna respay the all body, make it more flash, some one can help, suggest some workshop? thanks, sorry, about my bad enlgish
heya! i doubt alot of people will see this question in this thread...why don't you start a new thread?
That Orange YSL guy loves to run, looks ruff sounds mean. Tell him i want a rematch!
Saw GTR032 on friday night at pennant hills, sorry bro forgot ur name. Oh an the service Black Stump at Pennant Hill sux big time!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
