Last Night Wed (23rd) on Victoria Rd from West Ryde to Roselle. Spotted 3 R34s (2 black and 1 blue i think) all next to each other, they were obviously friends, all were done up quick nicely.
Came up to them in my 34 and we pretty much cruised together from ryde to roselle, giving a few small bursts now and then, nothing silly.
Was quite a pleasant trip to an otherwise pretty dull everyday commute.
So hey guys i was in the black spoilerless, cwest/kit 34 .
At about 11am I saw an orange line parked in Roselands Shopping Centre - YSL??? - looked like it could do with some work - Green P Plates.
Then on the way back home on Parramatta Rd, Auburn - saw a blue line, blue number plates "SY" - pretty awful turbo if you don't mind me saying. I was cruising in my mate's Astra and she was still able to beat it!
saw a yellow R34 drive past the ranch on friday night, didnt get the plates I was inside as it caught my eye out on the street, and saw I silver GTR in west ryde, parked in a no parking spot as they went in to get some drinks from the pub, then got followed by an undercover cop ...
i am a new member, i own r33 GTS for 1 year, i wanna respay the all body, make it more flash, some one can help, suggest some workshop? thanks, sorry, about my bad enlgish
heya! i doubt alot of people will see this question in this thread...why don't you start a new thread?
That Orange YSL guy loves to run, looks ruff sounds mean. Tell him i want a rematch!
Saw GTR032 on friday night at pennant hills, sorry bro forgot ur name. Oh an the service Black Stump at Pennant Hill sux big time!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
