Last Night Wed (23rd) on Victoria Rd from West Ryde to Roselle. Spotted 3 R34s (2 black and 1 blue i think) all next to each other, they were obviously friends, all were done up quick nicely.
Came up to them in my 34 and we pretty much cruised together from ryde to roselle, giving a few small bursts now and then, nothing silly.
Was quite a pleasant trip to an otherwise pretty dull everyday commute.
So hey guys i was in the black spoilerless, cwest/kit 34 .
At about 11am I saw an orange line parked in Roselands Shopping Centre - YSL??? - looked like it could do with some work - Green P Plates.
Then on the way back home on Parramatta Rd, Auburn - saw a blue line, blue number plates "SY" - pretty awful turbo if you don't mind me saying. I was cruising in my mate's Astra and she was still able to beat it!
saw a yellow R34 drive past the ranch on friday night, didnt get the plates I was inside as it caught my eye out on the street, and saw I silver GTR in west ryde, parked in a no parking spot as they went in to get some drinks from the pub, then got followed by an undercover cop ...
i am a new member, i own r33 GTS for 1 year, i wanna respay the all body, make it more flash, some one can help, suggest some workshop? thanks, sorry, about my bad enlgish
heya! i doubt alot of people will see this question in this thread...why don't you start a new thread?
That Orange YSL guy loves to run, looks ruff sounds mean. Tell him i want a rematch!
Saw GTR032 on friday night at pennant hills, sorry bro forgot ur name. Oh an the service Black Stump at Pennant Hill sux big time!
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
